Old May 24, 2014 | 05:36 PM
onehundred80
Default Re: Rough Idle/Gas pedal not working/stalling
Originally Posted by Davidm781
So I got my car a couple days ago everything was running fine. This morning I went and started my vehicle (didnt let it warm up) started driving down the road and all of the sudden the car started bouncing from 600-1100 RPM'S and the gas pedal was not working. So I pulled over shut the car off turned it back on a couple of times and it wouldnt idle right. I disconnected the battery terminal put it back on after about 3 minutes and the car ran fine all day today. About ten minutes ago I go to start my vehicle and it started idling rough right when I started it. I let it warm up and then shut it off removed the terminal again and figured the problem would be gone. Put it back on started the car and it did not correct the problem. Gas pedal was unresponsive and was idling very rough so I just backed it back into the driveway but when it was in reverse the idle seemed to geta little bit better and the gas pedal worked in reverse but not responsive in drive which I thought was very odd. I do not have much knowledge of these cars. I changed the oil the other day with Mobil 1 OW40 and flushed the radiator. Ive also looked around the page before posting only thing I could come up with was maybe it was the CPS or the MAP sensor help please
Throttle Position Sensor in the throttle body, air leak or accelerator pedal fault?
Check for engine error codes to make sure.
