Re: New Member in Kent ... help needed.
onehundred80
So what is the secret answer to Bens problem?
Top and/or bottom bushes!! With it jacked of the ground, holding the wheel at 12 & 6 there is play, but at 9 & 3 none! could also be wear in track rod ends?? not got the means to get underneath to confirm.
Both should have been picked up on MOT! but as we know MOT is only a guarantee of road worthiness for 15 mins after test. After that it is only a certificate to say it has had an MOT. And, if you take it back after the 15 mins you have to prove that the problem existed at the time of MOT.
