Old May 27, 2014 | 08:11 AM
onehundred80
Default Re: Hissing Sound from rear!
Originally Posted by Tommyj
Hi All,
In the last couple of days I have noticed a hissing sound from the top of the boot/trunk. It seems to only happen when I lock and unlock the car using the key.
Its been raining quite abit in the last few days, and wondered if that could have caused anything?
Everything works ok, but just wondered what this could be.
Many Thanks
The hissing sound is most likely the pneumatic line that actuates the lock in the hatch, the line is probably cracked and has not broken completely if the hatch still locks. If the hatch does not lock then it is broken entirely. You should replace the line with a better quality one or put a tight fitting sleeve over it.
The break will be in or near the rubber corrugated boot at the top of the hatch. Listen for which one it is.
