onehundred80
The hissing sound is most likely the pneumatic line that actuates the lock in the hatch, the line is probably cracked and has not broken completely if the hatch still locks. If the hatch does not lock then it is broken entirely. You should replace the line with a better quality one or put a tight fitting sleeve over it.
The break will be in or near the rubber corrugated boot at the top of the hatch. Listen for which one it is.
Just been out to look and it seems to be coming from the rubber sleeve area at the top of the hatch near the hinge. If I put a tight sleeve around that, would that stop the hissing or would I need to remove that then put the tight sleeve?
Thank you.
