Old May 28, 2014 | 11:53 AM
  #218 (permalink)
mobilefitt's Avatar
mobilefitt
Default Re: Crankshaft Position Sensor
so, I bent the prongs on the advanced part and used some di-electric grease to improve contact on the sensor. That did the trick. The sensor is working fine now, the wire is not damaged or the connector. The connector has been stretched by the bosch part and is not making good, consistant contact with the advanced part. Now that I tilted the prongs, sensor works AOK.
