Old May 28, 2014 | 02:25 PM
  #43 (permalink)
ala_xfire
Default Re: Heat-related misfire issue (P0300, P0302, P0305, etc)... need help!!
Not what the repair manual says about the two plugs :
The two spark plugs per cylinder are fired slightly out of phase to prevent the cylinder pressures from rising too
quickly, which could cause knocking. To prevent one spark plug from eroding more quickly than the other, they
alternately lead each other.
Under normal conditions, the timing is the same for all cylinders, but the timing can be
delayed in individual cylinders if knocking is present in one or more.
