Old May 30, 2014 | 06:58 AM
Dennis B's Avatar
Dennis B
Default Re: No more Sticky Key!
Hi Billy Dee
the fix is not hard, on a scale of 1 to 10 it's about a 5 (4 if you are good at limbo)
there is alot of info here on this, I recommend you read as much as you can about it
I don't know how to add a link to the PDF, maybe someone here can help with this?
You need to try to get the key to turn
try turning the wheel until it locks, then turn the key and wiggle the wheel
at the same time. during the repair you will have to remove the key and replace it
when you remove the 'ring' around the key cylinder
when you are finished, I'm sure you will have a $1,000 smile in your face!
I hope this helps
Cheers
Dennis B
P.S. In the PDF there should be a step 4 1/2. the headlight **** needs to come off
turn it one click to the right and pull. if it won't come, use a small screw driver to help pry it off
I had to do this, and it came off with no damage
