Old May 31, 2014 | 06:20 PM
Silverarrow's Avatar
Silverarrow
Default Help needed badly, ASAP
Hi everyone,
As you know I have been struggling with the engine code P1107 which says that the map sensor circuit is low voltage.
I have tried everything and done all kind av tests according to the manual. I have recognized one thing though. According to one diagnostic test it says that if the voltage is between 4.7 - 5.2 volt when measuring the voltage on the map connector when the ignition is on then I have to change the power control module.
I was wondering if anybody here on the forum can measure the circuit voltage on the map sensor connector when the ignition is on. Just disconnect the map sensor and measure the voltage over pin 1 and pint 3.
If someone here has the custom manifold from needswings it would be a lot easier because the stock one is sitting on the intercooler which is hard to get hold on.
I will go to the garage within 8 hours and would appreciate if somebody could help me.
Thanks in advance
