Old Jun 6, 2014 | 01:36 AM
  #58 (permalink)
JHM2K's Avatar
JHM2K
Default Re: Heat-related misfire issue (P0300, P0302, P0305, etc)... need help!!
FRIDAY UPDATE:
Car is back home, and running stronger than ever.
After it was all said and done, the "mods" I blessed the car with last September all came off except the 61mm pulley... LMAO!
Below is the video from the dyno run... healthy numbers considering it's on the stingiest dyno in the southeast
https://vimeo.com/97494837
AFR's are in the healthy (and safe) 12.5-11.9 range, using stock injectors and a Walbro 255.
Graph is attached:
