Re: Wanted
carl graham
George: Got thanks for the info... Carl
If you look at your photo you will see that the wiper arm spindle and the hole in the cowl are not on the same center. For this reason I suspect that Karmann did not instal the isolator (05101283AA) in many of these cars.
To correct mine I recut the hole on center, the original hole in the cowl is a bit too small so there is material to be taken out anyway, what we take away is concentric to the wiper spindle. I did a 'How To' PDF and it is attached here.
I found a juice cap that was the correct size (Ø1.70) and put a hole the center the same size as the OD of the wiper spindle (Ø.47) and scribed around the cap.
