Old Jun 13, 2014 | 02:16 PM
STEPHENJXN's Avatar
STEPHENJXN
Default Re: Blue tooth adapter for my 2007 roadster?
[QUOTE=ToneRaider;799570]I just did this this weekend. I used an FM modulator (iSimple from Amazon) that plugs directly into the back of your stereo into the antenna port. The signal is strong and no static.
Then I used a bluetooth receiver and plugged it into the new "aux in" instead of using an audio cable
I wanna do the same thing to my factory radio. I dont want to buy another unit. I would do the same setup. Where did you get the aux jack and where does it plug into the radio? Douse it plug into the "Simple" FM modulator? Hows the radio reception with the device installed?
If I purchased a head unit I would purchace a unit that has a rear view camera. The camera would turn on only when the car is in reverse.
