Re: Still pulling to the right..
He is right that it doesn't have caster adjustments. The front can't adjust much in caster or camber because of the factory adjustment bolts. From my understanding there are two bolts at each front wheel. One adjusts camber and one caster. You can buy and install the camber bolt kit from Needswings and this can be adjusted. Mine pulls a little to the left. I bought the kit, but mine doesn't pull enough for me to justify the trouble to install the bolts (or money for someone else to install), so I put them up for sale in the forum sale section if you want them.
