Old Jun 17, 2014 | 10:04 AM
Sennaspirit's Avatar
Sennaspirit
Default Re: "No Start" on eBay - cheap
Nick, there is a common issue with the No start that has a relatively simple fix. Using the instructions in the post on No Start, I was able to pull the trouble some circuit board, solder it (as indicated) and have not had an issue since. Now there are other issues that can cause the no start, but if this is "typical" variety, it certainly and easy fix. Plus, if you don't want to do yourself, there are members here who will do the fix for you...love the xf forum!
