Old Jun 17, 2014 | 02:53 PM
Avantidude's Avatar
Avantidude
Default Re: Cooling system fan question
180, I will check, it had all kinds of codes, when I picked it up. The car belonged to a guy that lived in El Dorado hills ca, he died it sat for two years, then his Son in Madera got it, nothing worked on it acc wise. When I got it, I pulled the fuses put new ones in it and the seats worked, windows worked everything but the air.
I replaced the FCM, the ac pressure switch, did the TPMS fix, the sticky ignition fix, pulled the in cabin filter, put the LED license plate lights although the driver side don't work I got power, but no ground, I am considering taping that brown wire and grounding it.
