Re: Car tuns over once then dies- New Remote/RCM fix done
Just taking a shot in the dark here but have you considered the SKREEM module? Could it have gone bad or gotten damaged when your ignition tumbler was replaced? Do a search on that and see if the symptoms match yours.
Also, have you checked under the foam in the trunk for water? The constant running of the pump makes me think you have moisture back there.
RL
