Old Jun 21, 2014 | 01:33 PM
rom173's Avatar
rom173
Default Re: Car tuns over once then dies- New Remote/RCM fix done
Originally Posted by RL67037
Just taking a shot in the dark here but have you considered the SKREEM module? Could it have gone bad or gotten damaged when your ignition tumbler was replaced? Do a search on that and see if the symptoms match yours.
Also, have you checked under the foam in the trunk for water? The constant running of the pump makes me think you have moisture back there.
RL
Thank you RL,
I will research the SKREEM module and keep you posted. My dashboard is still apart, so it shouldn't be too hard to locate. The water under the trunk foam would cause the abs pump under the hood to stay on? I hope I do find some water there, as I have not been able to start my car for around 2 years now. Water could have evaporated by now.
