Old Jun 21, 2014 | 02:36 PM
onehundred80
Default Re: Car tuns over once then dies- New Remote/RCM fix done
Originally Posted by rom173
Thank you RL,
I will research the SKREEM module and keep you posted. My dashboard is still apart, so it shouldn't be too hard to locate. The water under the trunk foam would cause the abs pump under the hood to stay on? I hope I do find some water there, as I have not been able to start my car for around 2 years now. Water could have evaporated by now.
The cheapest solution to this problem would be to find the small wire that connect the 'halo ring' around the ignition keyhole disconnected from the SKREEM or damaged in some way so that there is no power in it.
