Old Jun 22, 2014 | 01:18 PM
ala_xfire
Default Re: Questions about interior lights
Use an ohm meter and measure the voltage on pin 3 of the dome light connector with the switch in auto with the doors closed.
You should see 0 volts when you open a door.
Also at this time, measure pin 3 to ground, you should see close to 0 ohms.
