Old Mar 5, 2004 | 02:41 PM
crossfiretech's Avatar
crossfiretech
Default Service Action #04-005 2004 ZH Crossfire
Just came out today...Service Action #04-005 2004 Some 2004 Crossfires have the upper radiator hose too close to the radiator shroud.I'm assuming over time the hose could get cut.The upper hose should be 10 to 15 mm away from the two plastic bosses that stick out from the radiator shroud.If your hose looks 10 to 15 mm away your ok.If not the fix is easy, just loosen the upper rad hose clamp at rad and rotate the hose until you have good clearance.You might get a notice mailed to your home.This is something you can check yourself and save a trip to the dealer.If it doesn't look right bring it in to the dealer.I will post this in the TSB section.I will post when I hear any more info.
