Old Jun 29, 2014 | 03:40 PM
onehundred80
Default Re: Central locking not functional
Originally Posted by Frantisek Siskovic
Hi all,
I met some troubles using remote control to lock-unlock the doors-driver,passanger,back. I can do it only manually with key, now.
I checked all fuses and relays in underhood area and they are OK.
Is there any other fuse block related to power locks in car?If, yes, please let me know where.
Or do you have any other ideas? The truth is that I found some wet in rear trunk but I am not sure if there is some connection with failure.
Thanks for any response.
Frantisek
If the security/pump module under the foam in the trunk gets wet then you can expect problems. Take it out, dry it and clean the plug/socket terminals and hope it can be salvaged. they cost $200 to $300 used on eBay and $600 plus new.
