Old Jun 30, 2014 | 10:58 AM
ichon's Avatar
ichon
Default Re: P300 to P306 Codes
Basically this means that the the car's computer has detected that not all of the engine's cylinders are firing properly.
A code P0300 may mean that one or more of the following has happened: Faulty spark plugs or wires Faulty coil (pack) Faulty oxygen sensor(s) Faulty fuel injector(s) Burned exhaust valve Faulty catalytic converter(s) Stuck/blocked/leaking EGR valve / passages Faulty camshaft position sensor Defective computer
P0306....Misfire in cylinder #6.
