Old Jun 30, 2014 | 12:33 PM
05roadsterguy's Avatar
05roadsterguy
Default Re: Top problem help please !!!
So the top worked fine before the replacement and subsequent leaking? Sounds like you have quite the quandary there. I am not familiar with the power flow in the top operations, but it is downstream from the TCS. Now I am a little foggy on what exactly the Top Control switch is. Are you talking about the rocker switch that you push on the console, or the switch that actuates in the trunk well. Also You mentioned massive leaking form the top after it's replacement, What was the condition of the well? The deep area in the trunk under the styrofoam inserts. If it was full of water, you might have corrosion on all those connections.
I know thats not real helpful, but good exact informative posts and responses are what gets things fixed as opposed to frustrated rants. Keep your chin up, you have to be getting close to fixing it, is the company that installed the leaky top helping you pay for this?
