Re: Transmission will not shift from park No Start
You are 100% positive your brake lamp switch is good? These are common failures and a cheap fix. Buy one from a Benz dealer, DO NOT buy aftermarket.
When you turn the key, do all your accessories come on? If not, it could be your key or ignition switch.
Could be the shifter assembly. I have seen these a few times on 163 chassis ML's.
