Old Jul 1, 2014 | 08:27 AM
onehundred80
Default Re: Transmission will not shift from park No Start
Pressing the brake pedal activates the transmission lock, if it does not unlock then I suspect a problem with the lock, the switch or the power signal from the switch. As the lights do not work I would suspect the switch.
You can unlock the locked transmission using a tool pushed down the rear of the tranny selector, but I guess you know that.
