Thread: Top up problem
Old Jul 4, 2014 | 05:18 PM
onehundred80
Default Re: Top up problem
Originally Posted by Timesnow
Attached is the switch that I think is the culprit. Could someone compare it to the one on your frame? The little metal piece was bent so I tried to straighten it out and I’m not sure if it’s shaped correctly. The other question is how far down do you need to compress the switch before it actually switches.
Hook a bulb and a battery to it and check it.
