Old Jul 14, 2014 | 12:40 PM
Mel Gibson's Avatar
Mel Gibson
Default Re: Engine Turnover No Start
turn key on fuel pump comes on for 2 seconds, waiting for engine to crank (crank position sensor) engine cranks fuel pump comes back on. So you have ignition. volts to the pump fuel ,pump relay on if crank sensor is ok. then pressure to the injectors. If it fires with starter fluid I am guessing the pump. Fuel pumps last about 120,00 miles normally . So what did you find out?
