Red Runner
Brake Lamp/Speed Control is the number 2 fuse 15 amp blue located at the left bottom of the interior fuse block on the drivers side end of your console. Access is by opening the door. There should be a card on the back of the door describing the fuses. Interesting that this fuse controls both your Brake Lamp & Speed Control.
Great Thanks, I had already checked those just in case and all were ok, so the switch it probably is. I don't seem to have the fuse description on the back of the fuse box cover so your info was helpful.
Regards speed control, it does make sense as the brake pedal switches off cruise so they would both work off the same fuse and switch if one goes faulty.
