Old Jul 22, 2014 | 10:40 AM
grip grip's Avatar
grip grip
Default Re: Like New 19" Forgestar F14's
Originally Posted by rayth
Thanks, no issues on the inner clearance on the fronts? I've been wanting F14's and was planning on the upgrade over the winter.. I was planning on keeping 18s/19s but I could get behind 19s all around.. I'm assuming a shorter sidewall on the front to compensate?
hmmm you've got me thinking...
The wheels easily clear my 8-pots with 390mm rotors, so you shouldn't have a problem at all. As far as the sidewall heights, that would be up to you. Something like 285/35-19 in the back and 245/35-19 up front would look good also IMHO.
Here's an example of the above sizes, which has the rear tires approximately 1" taller than the fronts.
