Old Jul 22, 2014 | 07:14 PM
ala_xfire
Default Re: coverting base to power seats
Done carefully, you can supply fused +12v and ground to the seat harnesses with adequately sized wires and they will work fine.
Since the factory wiring uses a 30 amp fuse for each seat, I would recommend using the same.
Here is the connector for the passenger seat ( driver seat is the same ) : ( I think the '14' is the wire gauge )
