Old May 20, 2006 | 05:40 AM
bobs's Avatar
bobs
Default Re: Squeezing More Kw Out
Originally Posted by DOC CC
I'd like to know what's the best and no fuss method to increase pull away from the lights?
You could always press down on the accelerator pedal a bit further. That normally does it for me!
Seriously, do you have the automatic or the 6-speed? I can't speak for the auto, but I have found that with the 6-speed, first gear is very short and with proper application of the throttle and smoothly feeding in the clutch (a.k.a. "don't trigger the traction control or ESP") launches from a stoplight can be truly impressive.
As far as performance mods go, they have been discussed at great length many times before. Head over to the technical forums and poke around a bit, or use the "Search" function. I bet you'll find what you're looking for.
