pizzaguy
I can't tell you where the passage is, but I can alert you to one hazard: If the chassis ground connection becomes resistive, you are likely to blow up that nice new amplifier.
Here is a way around it - simply put a fuse in the 'ground' or negative lead as well as the hot lead. If the factory engine-to-chassis connection becomes resistive, the ground cable fuse will keep your amp from becoming the defacto ground return for the starter.
Just a suggestion, I know that fusing the 'ground' or 'return' line seems silly - but it has saved a few pieces of aftermarket electronics over the years. ANYTIME you run a ground wire direct to the battery, always fuse it. What ever rating the amp calls for for it's power lead, use the same rating for the negative lead as well.
thanks pizza guy, I will do as you instructed. Heck it sure won't hurt nothing and will be added protection
