Mrmiata
It's not easy to locate from the inside.. but about the center line of the battery and 2-3" down lower than the bottom of the battery.. so basically "transfer" that to where you are inside the car. Your going to be off towards the door side of things under there..
Thanks Mr M. I can take it from there and be sure to find it. I got the around about area to check and will not stop until I locate it. It is good to know that there is in fact a thru way. With that knowledge I am good.
I am just curious. Mr M and everyone else, what did you decide to do with all of the bundles of wire that was plugged to the factory amp. Did you just keep it there or locate the wiring harnesses elsewhere to get them out of the way, if that is possible
Everone we can consider this thread closed
