I had the same problem two years ago. The car would stall, sometimes even when I was driving. Friend of mine resoldered I think the fuel pump relay? and I have not had a problem since!
dnorm
When you turn the key to the run position (not start position), can your hear the electric fuel pump turn on to prime the fuel system? If you can't, I would revisit the RCM. I had this problem. When I looked at it, I could not see the crack solder joints. But when I took another look under a lighted magnifying glass, sure enough the cracks were there. I resoldered the the joints and have been driving the car for about a month without issues. Cheers. -Norm
