Re: Biggest stereo bang for the buck mod
Okay, I just finished installing the capacitors (I used 200uF) and pelked1's directions are impeccable. It took 1 hour total from start to finish. Afterward, I spent another hour checking out FM and various CDs at different settings. WHAT AN INCREDIBLE DIFFERENCE --- I AM COMPLETELY SATISFIED WITH THE FACTORY RADIO NOW!!! I can actually run the bass as high as +5 or +6 on some material, at +35 volume, with NO DISTORTION. Did any of you know that the subs will VIBRATE your teeth and THUMP you in the back, without distortion in the mid and high range? I actually had to decrease treble to 0 to even it out. I'm actually excited to pump up the volume again instead of groaning over the muddled mess from before.
Thank you so much pelked1!!! I have NEVER spent a better $5 in my life. If you want to enjoy your music, BASS included, instead of running it in attenuated mode, then you must install the capacitors. YOU WILL NOT BE SORRY!
