Old May 21, 2006 | 01:56 PM
intenseblu's Avatar
intenseblu
Default Re: Labor cost for Brake Job
Originally Posted by Irafatsar
The new pads generate more heat, for best results you should upgrade to slotted/drilled rotors, or you may warp the stock rotors. if you have any car experience, you can DIY. I don't have time so, I had the rotors and pads installed $100.00 bucks for the fronts.
my .02 cents
i highly disagree... most drilled/slotted rotors on the market are inferior quality compared to OEM and for street use, slotted/drilled rotors are not recommended due to lower durability... if you are going to warp your rotors from braking from high speed, it will happen on the OEM just as likely as the inferior drilled/slotted units, just don't do any heavy braking from 100 mph + and things will be ok... if an emergency happens and you do have to, you pay the price...
however, for looks, drilled rotors are great...
