Old Aug 2, 2014 | 11:45 AM
deerhunter's Avatar
deerhunter
Default Re: Removing gas door
OK
So I was thinking I would have to remove an external mirror for color matching
When the paint guy showed up
Open gas door, on the outer edge there is a small opening, use a skinny flat head
screw driver, insert into hole and depress a small plastic tab, then the gas door cover
slides right off. He had it off in less than a minute.
Oh ya, and to remove the door handles you must use a Screw Driver type 4mm hex
I was using a standard type L shape hex, didn't work so well. I learned that from
a Dealer Tech., who had both handles off in less than 5 minutes. I tried to tip the
fella but he wouldn't take my cash, he just told be to come back when I am ready
to put them back on. He restored my Faith in dealer,s but just a little bit though.
Thanks for all the help guys.....See ya at the Dragon
