Old Aug 2, 2014 | 03:29 PM
kuratsunade's Avatar
kuratsunade
Default Re: Canbus and lights questions
For the Crossfires,
License plate bulbs does not matter. So I used Sylvania/OSRAM bulbs that are $10 each. They are sealed, provides the best protection against moisture. You put them in, you just don't need to worry about them.
Amazon.com: Sylvania 6418 LEDriving Premium White Interior Light Bulb, (Pack of 1): Automotive Amazon.com: Sylvania 6418 LEDriving Premium White Interior Light Bulb, (Pack of 1): Automotive
There are various "canbus" LEDs that'll work with the Crossfire. I usually hunt them down on Ebay. Most of them works good without too high of a price tag. I have tested numerous LEDs that fits and doesn't trigger the "bulb out" warning ranging from $5 - $55 each set. If you buy those cheap ones from Ebay, just HAVE to make sure your headlight/taillight housing is sealed good, then they'll last you a long time. The link below has the seller info from ebay, I've bought couple from them. Despite they are not that high of a price, their customer support was good, they replace warranty claims quickly.
http://www.ebay.com/usr/epanda_house...p2047675.l2559
HID, I recommend using TRS(The Retrofit Source)'s Morimoto 3Five. They produces a high output if you stick with 4300K - 5000K bulb. Their "canbus" adapter is sealed, and works very well. You will need a set of those adapters. I have tried other "canbus" adapters from ebay and they don't seal them right and will always fail.
http://www.theretrofitsource.com/hid...l#.U90_j1YsKIw
I usually don't recommend using LED in turning signals. Just counter productive really if all you want to do is just stick a bulb in and expect to work. If you're interested in further modifying the housing, pigtails, then they maybe right for you.
I also don't recommend using HIDs in high beams, can't flash people anymore due to the latency of "firing"(ignite) the bulb.
