Re: Is installed the IC pump still doing same thing
see if the pictures help
PS - my install is probably not as pretty as others as I cut the old connector off to connect the new pump (with pigtails).
However this allowed me to hot wire the pump using the battery as shown.
If you have a neater solution with OEM plugs, I'm not sure how you can hot wire the pump.
