Old Aug 6, 2014 | 04:24 PM
ckovach's Avatar
ckovach
Default Re: Looking to have a go at some cork plenum gaskets...
Originally Posted by Buggin
I've had really good luck making a set from Mr. Gasket 9615 Compressed Gasket Material. I picked it up from Amazon. I traced out the plenums with paper and then transferred that to the gasket material. Using a mini grinding bit on a dremmel tool, I was able to almost perfectly gasket match the plenums. Since it's a compressed high-temp fiber material, torqueing the manifolds down properly is no problem.
Amazon.com: Mr. Gasket 9615 Compressed Gasket Material Sheet: Automotive
I like this approach...thanks. When mine come off again, I'll try it.
