Old Aug 7, 2014 | 11:38 AM
ala_xfire
Default Re: Roadster Rear Deck Lid Won't Latch
The latch for that is visible with the tonneau cover raised.
Examine it for any obvious problems, lube it up good with lithium grease and inspect the 2 hydraulic lines for signs of leakage.
You can latch the rear bow manually by using a 6 mm hex wrench on the latch when the trunk is open.
Press the rear bow down while turning the hex wrench, I don't remember which way, but pizzaguy ( Mark ) has a video on here you can search form he states which way latches.
