Do you think an easy out would work? If it was bound up enough to snap the bolt would an easy out be able to turn it. Sorry if that is a stupid question. I've used an easy out when a bolt head snapped off from over tightening, but never a cross thread situation.
Here are some pictures if that helps.
Bill F
You can get an easy out at Lowe's or Home Depot
GRABIT 3 Pc. AldenS Pro Grabit Kit
Compare
Rating 3.42 out of 5 stars (45 Reviews)
$19.98
Item #: 299780 Model #: 8430P
Quickly and easily removes most damaged screws such as Hex, Phillips, Torx, Square Drive; sizes No. 4 - No. 14 from wood, plastic or metal
Two-step drill bit and extractor in one tool extracts broken bolts and damaged screws fast; use in reverse only with 3/8"variable speed reversible...
Precision engineered for multiple extractions and maximum performance; self centering drill tip, no walking or wondering; works on jagged, uneven...
