Old Aug 9, 2014 | 01:00 AM
  #42 (permalink)
Black_X_Fire_04's Avatar
Black_X_Fire_04
Default Re: '04 Coupe Liftgate lock failure
Update: I snipped the line above the fittings and took a sharp blade, sliced the remaining and peeled it off. I am researching nylon, polyurethane, and polyethylene tubing at the moment. At this point I am leaning towards replacing the hatch tube with polyethylene tube due to its resilience when bending and flexing. Found a company that makes it in opaque yellow to match the stock tubing. Trying to keep everything as stock and clean as possible. When the job is finished I will try to post a tutorial with photos since this seems to be a big XF issue.
