Thread: Knock n Stall
Old Aug 16, 2014 | 12:36 PM
robby363's Avatar
robby363
Default Re: Knock n Stall
Was the washer fluid tank leaking after you filled it? The tank will only hold one gallon of fluid when the light comes on. If you try to top it off before the light comes on it usually gets over filled and runs out the bottom of door and fender onto the ground. You can get a fuel filter here. http://www.needswings.com/Bosch--Mah...024773001.aspx or most parts stores
