Old Aug 17, 2014 | 10:16 AM
ala_xfire
Default Re: crossfire cranks but will not start
88-92 3800's did not have a CPS :
1977 — Buick changed to an “even-fire” offset-pin crankshaft to smooth out the V6 engine.
1978 — Turbocharged version of the 3.8L V6 offered in the Buick Regal and LeSabre.
1979 — The engine gained some horsepower with improved cylinder heads (larger valves and ports).
1980 — Larger 4.1L version of 3.8L engine offered with bigger 3.965” pistons.
1981 — Stronger connecting rods and a revised harmonic balancer and flywheel were added.
1982 — 180 hp version of the turbocharged 3.8L V6 offered in Regal T-Types and Grand National. Also, a smaller displacement 3.0L version of the 3.8L V6 with a shorter stroke crankshaft was built for GM FWD cars.
1984 — Direct fire distributorless ignition and electronic multiport fuel injection were added. Also a new camshaft with a larger base circle and 0.015” shorter pushrods were added. This was also the first year for a front-wheel drive (FWD) version of the 3.8L V6.
