Cedar11
Are you talking about re-installing the original caps or new ones?
I have purchased new caps and the flange does not curve outward, so I am unsure how to install them at this point.
Thanks for the response
Either new or original, if they are the correct ones for the car they should go in, they need carefully lining up and maybe a touch of grease around the leading edge, they should then go in so long as they are correctly lined up.
Popping them in the freezer for a couple of hours first might help as they will shrink a couple of thou.
