Old Aug 20, 2014 | 08:40 PM
James1549
Default Re: Battery light on,AC went out,car won't run.....
From your symptoms, sounds like your charging system isn't keeping the battery charged to where it should be. Get the car started again and while the engine is running, you should be showing 14 volts on average. About 12.6 volts with the engine shut off. If it is anything less than 13.4 volts with the engine running, you have a charging problem, most likely the alternator.
James
