James1549
From your symptoms, sounds like your charging system isn't keeping the battery charged to where it should be. Get the car started again and while the engine is running, you should be showing 14 volts on average. About 12.6 volts with the engine shut off. If it is anything less than 13.4 volts with the engine running, you have a charging problem, most likely the alternator.
James
Thank you :-)
Question, I just read a old forum and it stated that if the TCM is plugged or gets wet it would run as I stated...so now I'm confused... I have it at a friends and I will let him know to ck both..I had a bad experience at the Chrysler dealer hear so I have no choice but to bring it to a local place.
Thank you,Denise
