cojoman
Thanks for writing.
I took the battery to auto zone and got it checked there. I also used the tester i have at home to test it out. It was 11.7 both in autozone and in my tester.
I tried putting a wire through the starter wire in the RCM to try to jump the starter, when i do that i can hear the starter try to spin but it acts as if there is no enough voltage for it and just slowly dies. I have a new starter that i bought. When i try running a cable from the same battery to the new starter, it spins and runs continuously. Mind you, the battery cables get very hot when i do this.
What exactly does this mean?
I always thought that no matter what, the key should at least make the starter that it has now to try and turn over(even if dies).
What do you think i should i do next?
