Re: New Owner from NNJ
Welcome to the Forum and congrats to a beautiful black Crossfire! I always loved the red/black interior. If I was to buy another Crossfire that interior would be my first choice. Looks like the headlights could use some sandpaper and polishing to make them look brand new.
The problem with the secondary air pump is a simple one and not nearly as bad as it sounds because in 95% of the cases there is nothing broken except for a bad joint on the Control Relay Module.
Do a search on the forum for error code P0410 and plenty of information will pop up. If you know how to use a soldering iron you can fix this within 5 minutes as you only have to touch up the broken joint and voila, everything smooth again.
However, unfortunately I don't own a soldering iron and have the same problem - there is very nice guy on the forum who goes by the nickname "tighed1". He will fix the broken joint for you and inspect the other joints on the relay. All you have to do is send it to him and he will fix and send back for $25.
Btw, I probably should add that the secondary air problem does not affect the car in any way and the car is totally drivable but I'm just tired of the Check Engine light popping up every not and then!
You will like the forum, lots of great information on our cars and all good people on here! Enjoy!
