Old Aug 27, 2014 | 06:22 PM
onehundred80
Default Re: Did I screw something up? Battery dead
You do know there is a procedure to disable the seatbelt chime don't you? You should reconnect the cut wire and follow the SIMPLE steps to disable it. Search for the procedure, it is super simple. You have to redo the procedure if you disconnect the battery but again it is real easy.
Here is the how to for the belt chime disabling.
Graphite Ghost wrote it. CLICK
